Did anybody developed a workflow for this task?
Thanks in advance.
MF
Thanks in advance.
MF
Thanks Matt,
It seems that ACIS SAT is the format to use importing from 3ds Max. The subdivision can be a little fuzzy with smooth surfaces but the important info comes through.
Best,
MF
Hi Marcello,
you can import meshes from other applications. If you are inside of an in-place family the mesh will take on certain properties of the mass once you hit 'finish mass'. You will need a closed volume in order for it to be used by conceptual energy analysis and other features.
-matt
