''IF'' function with 3 conditions in Dynamo?
is it possible to use the ‘‘if’’ function ( conditional statement) in dynamo with 3 conditions?
If inpunt a < 3 then function a
If input 3 < a < 4,5 then function b
If inpunt a > 4,5 then function C
Edit: Fixed my typo in the code below
You definitely can! Using a code block, type in the following:
input <= 3 ? functionA : input >= 4.5 ? functionB : functionC
thanks for your answer, it didn’t work, any tips?
Change =< into <= , or remove the = alltogether
Ah yeah, my bad on that one. Was on my phone without Dynamo at hand :frowning: Thanks for the righting of my off-course ship @Daan!
Like this @zzakaryae - My apologies on the syntax typo!
functionA = "I'm a funky Function called A";
functionB = "I'm a cool Function called B";
functionC = "I'm the fall-out stuff called C";
input <= 3 ? //if less than or equal to 3, return functionA
	functionA :
	input >= 4.5 ? //if greater than or equal to 4.5, return functionB
		functionB :
			functionC;
 //otherwise return functionC;
