I need to use the list in the pink box sequentially in the code box labeled “Variable”.
Can you clarify your question?
Concentrating on the Pink group. The box named " Variable" will run a process which I have test and works. What i want is for dynamo to substitute the value of “variable” and run the process on each item on the list. on the left of it.
You want to feed in the entire list not parts of it. Adjust your lacing and levels to accomplish this. Check the primer for examples of both, and check back in if you’re stuck after exploring that.
