i made a algorithm of floor boundary, and i want to make floor with that boundary
however in dynamo, it says that ‘Warning: FloorType.ByName operation failed.
A Revit FloorType with that name could not be located in the document’
i don’t have english family file, it is the reason of this problem?
if it is true, i should have to download english family?
i’m using korean family, it does not interoperate with korean library in dynamo??
thy^^
oh!! i found the reason that i can’t generate floor
first thing was i was using korean template, so i refreshed to use austrian template(the basic one)
second thing was i miss understood units!(there was limit value, so that i can’t generate floor)
Hello Yongil Park,
It is good that you found the solution to your problem.
I will look into why it was not working on Korean Template.
Thanks,
Ritesh
Thanks very much
Really appreciate you for your interests and im looking forward your answer
