I get the following error when sweeping
The error contents are as follows
Home.dyn (273.6 KB)
You need to join the curve before sweep
use PolyCurve.ByJoinedCurves
You should run Form.ByLoftCrossSection node on Conceptual Mass, if you need to make complicate mass structure.
