I was trying to combine two FilteredElementcollector with the method of UnionWith. But it is not working. what may the error in my code?
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
from System import Array
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import Mechanical
from Autodesk.Revit.DB.Mechanical import MechanicalSystemType
app = uiapp.Application
#######OK NOW YOU CAN CODE########
vid = uidoc.ActiveView.Id
collector = FilteredElementCollector(doc,vid).OfCategory(BuiltInCategory.OST_DuctCurves).WhereElementIsNotElementType().ToElements()
collectorfitting = FilteredElementCollector(doc,vid).OfCategory(BuiltInCategory.OST_DuctFitting).WhereElementIsNotElementType().ToElements()
union = collector.UnionWith(collectorfitting)
OUT = union
@SHIBUJOSE ,
at my knowlage you have to collect (with append) your elements…
like in this example… you can recreate your code
import sys
# import RevitNodes
# import Revit Services
# import Revit API
# import system.
import System
# get the current Revit document.
### ----------- FilterElementCollector --------------###
#All walls in project
collector = FilteredElementCollector(doc)
wallElements = collector.OfClass(Wall).ToElements()
### ----------- FilterElementCollector Active View --------------###
#All walls in active view
ActiveView = FilteredElementCollector(doc, doc.ActiveView.Id).OfClass(Wall).ToElements()
### ----------- FilterElementCollector search for 48" walls --------------###
#collect all walls in Revit then search for SW48
builtInCategory = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Walls).WhereElementIsNotElementType().ToElements()
wallList = []
for w in builtInCategory:
if w.Name.Equals("SW48"):
wallList.append(w)
### ----------- FilterElementCollector lambda expression --------------###
#lambda expression
walls = list(filter(lambda w : w.Name.Equals("SW48"), builtInCategory))
### ----------- FilterElementCollector using a filter --------------###
#Using a slow filter to get items.
builtInCat = List[BuiltInCategory]()
builtInCat.Add(BuiltInCategory.OST_Doors)
builtInCat.Add(BuiltInCategory.OST_Walls)
filter = ElementMulticategoryFilter(builtInCat)
elements = FilteredElementCollector(doc).WherePasses(filter).ToElements()
OUT = wallElements
understood. what is the use of UnionWith?
@SHIBUJOSE ,
i don´t know how to access this comment… at API docs there are still no examples
Can you post the dynamo results showing a collector that gets one duct, a collectorfitting that gets one fitting, and the union?
error is as below
union = FilteredElementCollector.UnionWith(collectorfitting)
It appears that you’re calling the class (FilteredElementCollector), and then it’s UnionWith method, as opposed to calling the UnionWith method on the previously created object (which is of the filtered element collector class).
Try collector.UnionWith(collectorFitting) as an alternative.
I tried that too. Unfortunately that also not working.
#union = FilteredElementCollector.UnionWith(collectorfitting)
un = collector.UnionWith(collectorfitting)
