How do i make a fixed distance so that the text do not overlap? and how to rotate the text vertically as the node seems to have bug for me?
For example, the distance between each text is 400mm apart.
You need to adjust the point for each text note. Currently you are using only 1 point for all of them. You either need to provide a list with the same depth with different points, or use a Range or Cycle node to change Point X value.
Try giving the “Rotation” input a value to rotate as needed.
That’s likely a list lacing issue as your text is @L3 but your points are @L2.
