# How to Place Multiple Groups and Rotate at the same time
**URL:** <https://forum.dynamobim.com/t/how-to-place-multiple-groups-and-rotate-at-the-same-time/7408>\
**Category:** Developers\
**Tags:** revit, python\
**Created:** [November 10, 2016, 9:10am UTC](https://forum.dynamobim.com/t/how-to-place-multiple-groups-and-rotate-at-the-same-time/7408 "2016-11-10T09:10:38Z")\
**Showing post:** 1
**Author:** ![Daniel\_Woodcock1](https://avatars.discourse-cdn.com/v4/letter/d/58f4c7/32.png) [@Daniel\_Woodcock1](https://forum.dynamobim.com/u/Daniel_Woodcock1)\
**Post date:** [November 10, 2016, 9:10am UTC](https://forum.dynamobim.com/t/how-to-place-multiple-groups-and-rotate-at-the-same-time/7408/1 "2016-11-10T09:10:38Z")
Hi all,
I thought I would start this thread off the back of another thread as it includes further functionality not specified in the original questions until after the questions were answered.
The aim was to place groups by coordinate, then place multiple groups by coordinates and, after a lengthy and abstract discussion, to do that with a rotation built-in to the node.
The script below does exactly this…
 ![](https://us1.discourse-cdn.com/flex022/uploads/dynamobim/original/3X/8/b/8b5f0273188879b398502c53e8cdf48887734396.png)
[PlaceGroup.dyn](https://forum.dynamobim.com/uploads/short-url/wK5DAL0EEBGsbEOmSyAsC4Tm3z0.dyn) (16.0 KB)
@RLietz this should answer all your questions in the posts below…😀
> [@How to Place a Revit Model Group?](https://forum.dynamobim.com/t/how-to-place-a-revit-model-group/7216/10):
> Hi @RLietz, Under each node lies a bit of code. In this case it is Python and it is what makes Dynamo a little more beautiful in my opinion. Although it can be done in C# using the zero touch interface, people can view the Python code and get an understanding of the Revit API and how to generate their own nodes, another thing which makes Dynamo beautiful, which is the sharing and development of the community. Did the node work for you? If so, could you please mark as resolved? Cheers, Dan
> [@How to arrange multiple Revit groups?](https://forum.dynamobim.com/t/how-to-arrange-multiple-revit-groups/7241):
> My poor brain still doesn’t quite get it with assembling recursive definitions to process a group of points, to be able to arrange multiple instances, in this case a group. When I feed a point list into Tool.PlaceGroupAtPoint, I half expected it to place the group at the nominated points from the list, however it only processed the first point. In the attached samples the graph works, but is not flexible for a changing number of points, is it possible to come up with a more elegant designed gra…
Cheers,
Dan
_[View the full topic](https://forum.dynamobim.com/t/how-to-place-multiple-groups-and-rotate-at-the-same-time/7408)._
