Hi All! I am curious how I could place a certain family type (100) times in one location.
I need these family elements in the model but not visible so I was going to place them away from the model.
Here is what I have currently tried and I was curious if there was a better way to do it so I could change the number of elements from 100 to 120 or 130 easily.
Notice it places them in a row. I was curious if I could get them all in one point.
Hi @NateWalchenbach i am curious too …can i ask why you want that
Great Question!!! I was hoping to have elements show up in a schedule but did not want to hand place them in the model!
Have you tried the OfRepeatedItem node with a single point and the number of instances you want to create?
Hey @Andreas_Dieckmann ,
Thanks for getting back to me! I did not try this but I actually figured out another solution which still works similar.
Here is a little script I came up with that does the following:
Creates a short line
Adds points on that line by a certain count (in this case 50)
Adds a family instance to every point.
Just curious. What sort of widget are you placing to schedule?
Unrelated to what you are drawing?
Hey @aaronrumple good question!
With the RHYTHM package, there is a node called VIEWPORT.CREATE
I take the schedule I want and add it with the following parameters.
Here is an example!
Here I do the following.
Add the sheet I want to place it on.
Take the view (the schedule you want to place)
The location on the sheet I would like it to be on.
And that’s about it. The schedule will update automatically in revit so as long as its placed the updating part is done automatically.
NateWalchenbach:
Well - my question was what widget is the schedule scheduling that you don’t want to see?
