Hey, I was trying to create 3d bridge model using dynabridge package however the package is not working properly. Can someone guide me on how to make local coordinates from excel read coordinates. I need local coordinetes to make a list with variable point amount for 2,3,4 adaptive component. You can see what I mean from below picture. Although Dynabridge package has this node already it doesn’t work with later revit versions. Hence, I would be glad if you can help me with this.
You might use Civil Connection package by @Paolo_Emilio_Serra1
You should give it a try it will lead you to your target smoothly.
