Thanks @Ge0rges, very smart.
It works good but the only issue I face is that one side is generated as a solid while the other side is generated as surface only.
This is because the profiles are not in the correct order.
I didn’t knew that solid by ruled loft node so pretty cool !
This is how I got all objects on layer to work. Typing the layer name directly didn’t worked nor getting the layer names first and selecting the one I wanted, I do think this is because of the special characters in the layer name but will need to further test.
Hi @david_licona
In my case typing tha layer name directly works. Tested it in the Dynamo player as well. works smooth and fine but does not generate a solid.
Sometimes the order may change. You have to rebuild to have the first profile at the beginning of the path, specifically in layer 1.
