How to isolate and select individual points from a list?
Is there a way to take the list of dots provided by the points tabs and isolate them so that I might choose and pick individual points for some nurb lines? Sort of like the list node but the opposite?
I’m new to dynamo so apologies if there is a simple solution I simply haven’t found.
If you right click on the node it’s self, you can toggle if it shows up if the preview model.
Screenshot 2024-07-08 182543
That’s not so much what I’m worried about, more so being able to take specific points from the array and then linking them into a nurbs curve and then a surface afterwards.
Regardless, thank you for taking time to respond.
List.GetItemAtIndex should work. You can also isolate via condition using a List.FilterByBoolMask node.
That sounds like the sort of thing I’ve been searching for. Let me give them a proper shake and I’ll let you know! Thanks!
Yup, this was exactly the thing I was looking for. Thank you!
