hi, community members.
I need to add the FULL SKY ILLUMINATION and DIRECT HORIZONTAL ILLUMINANCE data to the sky which automatically generated in Dynamo by the epw file and Climatebased.sky.
But the problem is image-based recipe node can not read the new sky txt file directly.
And when I see the output of the sky node, I noticed that it actually need an application called gendaylit in Radiance installed package to take the information and input it to the recipe node.
actually there is an option in grasshopper recipe node which allows the sky file to be ready directly.
Is there any possibility to read the sky file to recipe node directly?
thank you
