I need to get the density of a material. I tried the node “Element.Get Parameter Value By Name” but the density doesn’t appear in the parameters.
How can I get it?
Thank you.
How can I get it?
Thank you.
Hi Nicole,
You will find your answer in this post http://dynamobim.org/forums/topic/how-i-can-get-structural-aspect-aka-propertysetelement-from-material
In that post Dimitar has shown how to get material density value using Python script. Good Luck!
I tried in this link the script but I had this error in the script:
Avertissement:IronPythonEvaluator.EvaluateIronPythonScript l’opération a échoué.
File “<string>”, line 9, in <module>
AttributeError: ‘List[object]’ object has no attribute ‘StructuralAssetId’
How can I make the ‘StructuralAssetId’ for my object?
Thank you
Thank you Kulkul for the help!
