I’m trying to get the code inside a component as output.
For example, in Grasshopper, it’d be using ghenv.Component.Code
. What would be the equivalent way of doing it in Dynamo?
Also, are there hidden variables in Dynamo similar to grasshopper’s ghenv, ghdoc
, etc., Dynamo API Docujmentation?
I’ve seen this (Dynamo API documentation), but how do I use this? Neither direct import nor clr.AddReference
would work.
What I’m trying to do is something similar to the Ladybug’s Export Ladybug component (https://github.com/mostaphaRoudsari/ladybug/blob/master/src/Ladybug_Export%20Ladybug.py) so i could place my python scripts under VCS.
