Hi there,
Is that possible to get coordinates on a feature line’s both end? Please see the attached screenshot.
Thanks in advance.
Hi there,
Thanks in advance.
Select it and use object.geometry. then use get start point and get end point under the curves category. Thats as long as you want it in x, y, z. Do you need it in northing/easting?
I have tried the script that you mentioned, and it is not working on feature line. Please see the attached screenshot. Thank you.
Hi @SeanP
No, the post you have recommanded can help me to get the property of a feature line. However, it doesn’t work on extract the coordiate from a feature line. I have tried to use object geometry scripts to obtain the coordinate, but it is not working also.
Also just have to mention the fact that all three of us in this thread are named Sean. Let’s go Sean team! hah! (Even if I’m the Shaun variant )
