The node ScheduleFilter.ByFieldTypeAndValue has 3 input nodes, one of them being value which needs to be of type var.
ScheduleFilter.ByFieldTypeAndValue(field: ScheduleField, filterType:string, value:var): ScheduleFilter.
If I use a codeblock with code filtervalue: var =“Level 0”; this is still seen as a string and it it not accepted by the node ScheuldeFilter.ByFieldTypeAndValue.
How do I force the variable being of type var ?
Hello @leen.van.pelt
it’s indicated “var” because the values can be of type, Integer, Double, String or ElementId (Element)
The problem was actually that the first parameter was wrong, schedulableField should be ScheduleField. But you also showed a good example of how to “convert” it, with x[3] in your code block. I used a List.FilterByBoolMask to filter out the proper one by name.
Now I’m stuck with the ScheduleView.AddFilters node, it doesn’t accept the Filter, although I can manually create this filter. I’ll create a seperate post for this problem.
