i am trying to analyze the Velocity Drop in HVAC System, so i need the item where the velocity drops are.
if i get bools where the value is changing , it will be easier to find where the culprit is…
if i have…
{1,2,3,2,4,5,6}
in this case i should get false or true at value drop from 3-2.
This makes it more confusing as it sounds like it is no longer just a list of bools. Can you show exactly what you want the output to look like? Just put it in a codeblock.
By using UPSTREAM ELEMEMTS(by selecting the forthest air terminal) node you can get the connected elements towards the AHU.
Then by using GET PARAMETER VALUE node you can extract the velocities.
My 1st post is the output of velocities.
