I’m new to Dynamo and starting with something simple. I’m trying to find all panelboards with an ‘H’ in their name, and then checking those to see whether they have been assigned 277/480V (i.e. high voltage).
I’m trying to do this with a couple nested FilterByBoolMask’s, and it seems to be finding the right quantity of mismatched values, but it’s not identifying the right elements.
You first filter your panels by those with H but then filter the original list when looking at voltage. You need to filter the previously filtered list since that’s what you’re querying for voltages.
you are filtering a list that contains every panel in your project, including the ones without “H” on its name, that’s why you are getting a worng answer, the solution to what you need is to filter not every element but the “in” list of the first filter, in that case, the last watch node will give you the correct object name
Your script looks quite optimized, the only thing i would suggest is replacing the code blocks by strings and the for first node use family type by name because sometimes when using another dynamo version this selection could get reset.
