How to Enlarge or Increase size of a Family with help of Dynamo
I have created a Structural Pylon with the help of Structural Column family template but Structural framing family is used as an inner element, some other Generic models are also used.
I want to enlarge the size of this Pylon all together along with its Parameter.
When doing it on Revit the alignment of the inner elements get out of the range with main Structural Column.
Is there any command in Dynamo which can be helpful for me. If there is, please share with me the method, procedure or tutorial for guidance.
Attached are the pics below.
Another image showing the inner blends as Structural Column template family.
Inner Element
