Hi everyone,
Any idea how to divide curve by levels? I would create reference points on curve with z coordinates aligned to Levels
Other question : How to create multi Levels with dynamo? We must now type the level’s name, how generate multi name of Level?
Thanks!
You can use a bit of Python to extract the height from a level:
Great job,It works fine!
I'm now trying to comput the both files (I stick to my first idea, not without difficulties...).
Does it exist a way to extract coordinates XYZ from Level node?
No, the number node is just the normal built-in number node. If you enter the correct syntax Dynamo will generate those inputs for you. Have a look here:
http://buildz.blogspot.de/2013/09/sequences-and-ranges-in-dynamo.html
I installed the latest Dynamo's build 0.62 to get Lunchbox and Normalization in the package manager. But in this version, I can't find these number nodes you use. Must I download others packages to get them?
Thanks you so much Andreas,
I couldn't have found it alone. I'm going to try this.
