Conceptual Bridge
Hi Everyone,
New learner of Dynamo. I Try to make a conceptual bridge.
In the file attached, I would like to divide each circle by the same amount of points. But it divides only the first circle.
Does anyone know how to achieve this?
Thank you in advance for your reply.
Kind regards,
Vincent
Vincent, you don’t seem to have attached any file.
However, the problem, as described by you can usually be resolved by changing the lacing
Now noticed the file you’ve attached at the top of your post.
The lacing in your file seems fine, though.
Replaced the custom node with an OOTB node (not sure if it does the same as your custom node)
Altered file: Conceptual-Bridge.dyn
