Hi everyone,
i am looking dynamo for create a detail line for in between two family like autocad block.
kindly help me.
thanks
thajmul
What script have you made so far?
hi,
i did not make yet. Actually, i don’t know what are the nodes need to make for the family.
could you tell me? how to make?
thanks
thajmul
Yes you start by learning Dynamo. A good series to learn from is this:
hi,
thanks for the reply.i try to make script for family after complete the tutorial. if i could not able to create the script, could you help me?
thanks
thajmul
Hi @thsa2501 is it an annotation family something here could probably work
hi sovitek,
i will try for that one.
thanks
thajmul
hi,
where will i get Geometry.splitBytools node?
thanks
Ampersand
hi,
i am trying to make for multiple elements.it works one time but when i am trying to make another multiple elements. the line disappear for which i done last.
thanks
thajmul
Home.dyn (55.8 KB)
Hi thats element binding, try run from player or try clockworks detailcurve, that node dont have binding
hi,
i am trying to trim line crossing the elements but i can’t.please help me.
connect elements with line.dyn (20.7 KB)
sorry for the late reply. i tried as much as possible.it is not works. i am getting error message at CURVE.POINTATPARAMETER node.please find attached file.
connect elements with line.dyn (24.2 KB)
Hi Sadam
arhhh its on a firealarm family, i thought it was an 2d annotation family, i will take a look later today
hi,
thanks for the kind replay.no problem.take your time.
thanks
thajmul
its a nested annotation family, try something here it could probably work in your case…
connect elements with line (1).dyn (25.0 KB)
thank you so much. its works now. you made my day
thanks
thajmul
