How to create callouts from link
Hi, I am trying to create callouts for curtain walls using this graph , it is running well but the curtains created on link not on main project so i tried to get all wall types from link to read it
Unfortunately can’t upload revit file.
crop view test 2.dyn (68.4 KB
@jacob.small can you help me?
I’m traveling till Thursday at which point I will have to look at how much catch-up I have to do, so I can’t just yet. I will not that as you are not providing the link and host model you are asking 20 minutes to set up a project that might look like yours. I say might as the Revit version is unknown as is the link structure (internal origin to internal origin, or something else?), so we aren’t likely to mirror your setup.
Ok will create an example and upload, thanks.
crop view_test.dyn (98.9 KB)
Project1.rvt (5.6 MB)
test 2.rvt (5.2 MB)
Still can’t find a way to solve it, here are the files project1 is a link @jacob.small
Have a holiday today so I am not at my CPU, but I’ll try and have a look Monday.
@Deniz_Maral @Kulkul Kindly, can you help me to solve this issue?
I would suggest you to use BimorphNodes. You can get walls from the link and then you must transform the geometry. If the link and main document don’t share same coordinate system.
It worked, I appreciate that :pray:
