how can i script the following simple geometry (a concrete floor on piles)
(top view of the floor)
Input:
• floor length 4m
• floor width 4m
• floor thickness 0,2m
• The distance between the centre of the piles: 2m
• pile dimensions: 0,25m * 0,25m
• Pile length: 10m
Output:
The geomtrie will be something like this: a 3d concrete floor on piles
@zzakaryae ,
here is some raff idea… you can modify the script!
createRaffIdea.dyn (52.1 KB)
@Draxl_Andreas thanks for your answer. the piles should be under the floor. so from 0 to -10m en not from 0 tot 10m. how can modife it?
hey @Draxl_Andreas,
can i get the dynamo model of yout script if possible?
@zzakaryae ,
just rebuild the currend graph… as you can see in the pics…
“I can show you the path…BUT”
KR
Andreas
