Hey, I have to convert very large double number to long. could anyone help tel me how to convert double to long? many thanks.
Can you post a picture of what you have tried or what you are trying to achieve?
You may need to add a little more information to this request or give some context, so that others in the forum can offer the best advice.
OUT=[int(i) for i in IN[0]]
Thanks Ewan, nearly there. only second part in the schedule, that will be great if the first part in the schedule.
Apologies try this:
Have another look at the picture I uploaded.
If this is the way you are going to go, then you will need to Transpose the values then use the correct list
(i.e. the first one)
It still doesn’t work.
What values are reporting in the List.Transpose node?
The values from the String.Split node will need to be at the top level of the list for List.Transpose to work as I have shown.
You may need to look at using the list levels function.
http://dynamobim.org/introducing-listlevel-working-with-lists-made-easier/
drop your files please
I am a new user, can’t drop a file to here.
send a link Please
Here you are. Thanks for help.
https://www.dropbox.com/preview/Point/point%20locator_SH.dyn?role=personal
