Hi everyone,
I am running into an issue collecting windows that are acting on a space. In the image below, the red outline is one space and I am using the GetSurroundingElementsInDocument node with a tolerance of 0 but it is still including the window in the blue circle in the space. Does this node use a bounding box with min and max point to define its region? Is there a way to exclude that window from the space?
Thank you!
Mitch
