Hello all,
I would like to build a loft surface using crossection and guide by extracting curves from the available boundary points. What will be the ideal node to achieve this ? How should I proceed.
Please suggest
Regards
Hello all,
Please suggest
Regards
I would do this manually. It is achievable automating it (i.e. using Dynamo), but the amount of time it would take and the fact you will be forced to find a solution which only works with your current arrangement of points meaning it will only be useful once…you could have just drawn the curves in a CAD application yourself and then you can invest your time attempting something that’s going to benefit from a procedural process!
