I want to move and rotate within Drafting Views,
operating Detail lines and text in.
How do use the method of operating it?
Thank you very much!
If the content is not instantiated via your definition it will very likely require duplication of the existing elements in order to translate/modify them. It is possible to manipulate model elements that are not being driven by an active dynamo routine but you must do it via python. Perhaps the same approach can be recycled for detail elements?
