How i can uncut the reference plane
here is there any Node or script which will work ?
hi im afraid its not possible with api as we can in revit ui, as far i know, but you can split the beam or create a void on that replane and use that for cut
arhhh mean uncut then just delete the refplane
@sovitek Uncut :wink:.
Not sure if inget the question from OP.
I am getting he wants to uncut a cut
Element.
Not sure if that is possible.
If not. recreate the same Element in
the same location and delete
the cut one maybe?
yeah Bas early in the morning :wink: gabbbb
yes, this will loss the tag or DIM provided.
oh i see.
Maybe this?
yeah sure but not refplanes, so far i know :wink: so i would try just delete the refplane and if keep that refplane after uncut the just create again in same run…my best idea for now
okay, thanks let me know if you get any idea in future
yeah i will do :wink:
Revit_woDcfIGClm
I was just about to suggest this as well! But I was going to suggest deleting and recreating all reference planes as from the previous post it sounds like there is a difficulty finding the plane associated with the beam.
but the problem here is, what if the reference plane used to cut many framing, which i want to retain​:grin:
not sure do you mean as here
Revit_MDQjy10lX5
