I have a list of sheets that I create and I need to place specifications on them, thanks
What have you done so far?
I tried using steamnodes to add a view to the sheet, but it doesn’t work, because an error appears that the specification is larger than the sheet
as I understand it, the type of detection itself and the specification on the sheet are different elements for revit
Post what you’ve done - screen grab is good.
Think you need to insert In a point so you are sure the viewport intersect the sheet
