Hi guys, how can i creat a ambient mass like this? A module that is repeated in environment changing his form, thnxs
Hello, have you watched the official Dynamo tutorials? There’s something very similar to this in “Unit 3: Working with SAT’s”. While you don’t have to make an SAT for it, the process should be very indifferent. I would make a solid box with massing in Revit, and then make a void out of it with the desired shape. Might have to make the substraction in Dynamo so your script could read it better. You could also make the form in Rhino, and import it into Revit using an SAT of course. Hope this helps a bit, and if it doesn’t, reply your problems.
Thanks this help me a lot!
