Hi! I’m using Synthesize Node “Generate Model or Detail Lines” to get detail lines out of a polycurve. How can I get the center points of each detail curve?
point at parameter 0.5
I’ve tried that already. This node needs regular “curve” as input. I get error, because output from synthesize node is “detail curve”.
Just get geometry from element to convert to dynamo curve.
Thank you very much I couldn’t find a node translating detail curve to curve. Now it works perfectly
@sed07 This solution is also ok, but for my further needs I would have to flatten the list. Johannes solution is one step shorter
