Hi I’m having some serious relationship issues with Dynamo Studio.
When trying to use horizontal frames at parameters I seem to get the frames almost as though they have been normalised, rather than at the parameters that I specified.
Whats even more frustrating… the ordinates appear correct. Am i missing a trick somewhere.
I am running DS1.3.0.881.
Could some kind gentleperson have a look
at the two curves (a straight line and a simple nurbs) in order that I retain my sainity.
thanks
Kenyon
Horizontal frames_why.dyn (15.3 KB)
It looks like you’re trying to drive a family element in Revit, yes?
Check that the RFA file doesn’t have the ‘Always Vertical’ parameter set. If it is a face-based family you will also have to first define a Reference plan before placing it.
If you’re trying to place a two-point-pick family, try sending two points as the Geometry you pass to the Instancing node.
Hi Adrian, thanks for the response, I am running Dynamo Studio, outside of revit and pushing data into SAP2000.
I also tried to run the DS definition with Dynamo within Revit (I’m back in the office) same result.
Seems a little odd.
rgds
Kenyon
