Hide only rectangular duct centerline
Hi Everyone,
Is there a way of hiding center lines of only rectangular duct. I have rectangular duct connecting round duct and I want to hide center line of rectangular duct and keep the center lines of round duct (to differentiate between the same) . Is this possible?
Cheers
Any screenshot, illustration, link…?
I don’t think this is possible as they are the same category, just a different profile. The only solution I can think of is to:
  • Set the view to hidden line style
  • Create a filter for round ducts
  • Set round ducts to be 100% transparent
This will show the centreline for the round ducts but not for the rectangular ducts. Just depends if you want your view to be this style.
TJ
Hi Yna
. I want to hide the center line for rect duct some of the fitting family does not show center line, but the straight bits show.
Cheers
Hi Tom,
Your are right, if I hide the center line it hides for both. Hidden line style won’t work as I need to see the insulation .
Cheers
Hi Tom,
Thanks for the solution, It worked. In each view, I changed the discipline to mechanical and left transparency at 0
Cheers
