Hi everyone, I have a sleeve model and whenever a revision is made, I have to check which one is revised following 4 these items (my idea is check the revision between current model and former model):
- New sleeve
- Deleted sleeve
- Changed position sleeve
- Changed size sleeve (for instance if a sleeve has been changed from 200m to 150mm in diameter)
For that reason, I tend to create a graph that I can check it precisely and quickly. For now, I can deal with the 1st, 2nd, 3rd items but not the 4th. I try to get the bounding box of elements that exist in both model (current and former model) and check the difference of them, but maybe it’s not a correct way.
So please help me with it? This is what I’ve got so far:
Check SUD change.dyn (122.2 KB)
I’ll be very appreciated. Thank you.
