Hello, I’m having a issue with parameters being set to hidden or filtered off assemblies. I created a script to get and set parameter, the issue now is I’m needing the parameters to be set only to my active working view and not to what hidden or filtered off. Any help would be greatly appreciated.
Jes Assembly Get Set Parameter.dyn (18.3 KB)
Try all elements in active view, or all elements in view by category (I believe that is in Datashapes), or just select model elements (if you’re making the user open a view and isolate elements it’s likely just as quick to have them select the element).
Not sure where to place All Elements in Active View, Is there another node i need to connect All Elements of a Type and Elements in Active View. I’m still a novice when it comes to Dynamo.
