HELP! Select element in the view
Hi
I want to select those warnings in my view {3D} to isolate them for a clear view and modify.
Thanks for your help.
What is the error? seems you did fine.
Hi, the problem is that nothing was selected in revit!
what you want achieve here, i can help you?
try like this?
Select in revit.dyn (13.8 KB)
You can also isolate the view for better visibility.
Alternative; PyRevit > EF-Tools.
I REALLY appreciate your help, but I only work with Revit 2021 so it doesn’t open in my version and I tried to do the same as you did but there is some element that doesn’t show up
Hi, thanks this solution solved what my ecu
is there a way to isolate them? is just colored them in a new veiw
This is a problem as you’re 2 years after the end of support so you haven’t been getting any security updates, including a possible doozy that allowed arbitrary code execution by just opening a maliciously crafted Revit file (rvt, rfa, rta, rft, etc.).
yes i think thats the problem. Thanks
