I am trying to create a recursion function using iterations , in a brief the function checks if the iteration is equal to zero , if it does the function stops , if it doesn’t the function starts and at the end it returns itself and it returns iterations -1 to determine the recursion steps , like the following ;
Thank you very much for your reply , it worked , I am used to script in Rhino which runs the function then return the polygon and the “finished” results , it confused me but now it worked thanx again
Thank you very much for your reply , it worked , I am used to script in Rhino which runs the function then returns both the polygon and the “finished” results , it confused me but now it worked thanx again
Glad it worked out for you. Can you mark @mellouze’s post as the solution so if anyone has the same problem in the future, they can find the answer easily?
