Hi everyone!
I’m trying to remove the units from a custom node that enables me to take “Type Parameters” from my Revit families.
Hi everyone!
Sorry for the double post, the edit button does not seem to work. The warning says “Dereferencing a non-pointer”
Hello Wulfrum,
You can directly pass output of String.Remove to String.ToNumber, you don’t need SIUnit.Value.
If that doesn’t work, then please add screen shot with Preview expanded.
Thanks,
Ritesh
Hi Ritesh,
I tried your suggestion but to no avail.
maybe you show your data and definition.
i doubt that your string is representing just digits???
Hello Wulfrum,
Can you attach output of String.Remove to watch node and post scree shot. I want to see what is the output from your Custom Node (TypeParameter.FrmFamilyInstance) as well from your String.Remove Node
Thanks,
Ritesh
