# Grid extents alignment based on crop region
**URL:** <https://forum.dynamobim.com/t/grid-extents-alignment-based-on-crop-region/55538>\
**Category:** Revit\
**Tags:** python\
**Created:** [September 25, 2020, 6:07am UTC](https://forum.dynamobim.com/t/grid-extents-alignment-based-on-crop-region/55538 "2020-09-25T06:07:04Z")\
**Showing post:** 6
**Author:** ![c.poupin](https://sea2.discourse-cdn.com/flex022/user_avatar/forum.dynamobim.com/c.poupin/32/89152_2.png) [@c.poupin](https://forum.dynamobim.com/u/c.poupin)\
**Post date:** [September 30, 2020, 3:46pm UTC](https://forum.dynamobim.com/t/grid-extents-alignment-based-on-crop-region/55538/6 "2020-09-30T15:46:36Z")
Hello @dhilipseshan
I had not considered this scenario 😀
try this version
- Edit 03/02/2022
fix bug
```auto
import Autodesk.DesignScript.Geometry as DSGeo
#import Revit API
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
app = uiapp.Application
sdkNumber = int(app.VersionNumber)
def createDatumLine(boundLines, grid):
	gridLine = None
	curveG = grid.Curve.ToProtoType()
	vectGrid = curveG.Direction
	ptmid = curveG.PointAtParameter(0.5)
	lstPtToLine = []
	for lineBound in boundLines:
		lineBoundDs = lineBound.ToProtoType()
		ptmid = DSGeo.Point.ByCoordinates(ptmid.X, ptmid.Y, lineBoundDs.StartPoint.Z)
		interResultA = ptmid.Project(lineBoundDs, vectGrid)
		interResultB = ptmid.Project(lineBoundDs, vectGrid.Reverse())
		if len(interResultA) > 0:
			lstPtToLine.append(interResultA[0].ToXyz())
		if len(interResultB) > 0:
			lstPtToLine.append(interResultB[0].ToXyz())
	if len(lstPtToLine) == 2:
		gridLine = Autodesk.Revit.DB.Line.CreateBound(lstPtToLine[0], lstPtToLine[1])
	return gridLine
def getBoundLines(bbx, Zvalue = 0):
	lstPt = []
	lstLine = []
	lstPt.append(XYZ(bbx.Min.X, bbx.Min.Y, Zvalue))
	lstPt.append(XYZ(bbx.Max.X, bbx.Min.Y, Zvalue))
	lstPt.append(XYZ(bbx.Max.X, bbx.Max.Y, Zvalue))
	lstPt.append(XYZ(bbx.Min.X, bbx.Max.Y, Zvalue))
	for idx, pt in enumerate(lstPt):
		if idx == 0:
			lstLine.append(Line.CreateBound(lstPt[- 1], pt))
			lstLine.append(Line.CreateBound(lstPt[idx - 1], pt))
	return lstLine
activView = doc.ActiveView
cropBox = activView.CropBox
fecGrids = FilteredElementCollector(doc, activView.Id).OfClass(DatumPlane).ToElements()
cutOffset = fecGrids[0].GetCurvesInView(DatumExtentType.ViewSpecific, activView)[0].GetEndPoint(0).Z
fecGrids = [x for x in fecGrids if isinstance(x, DB.Grid)]
outLst = []
boundLines = getBoundLines(cropBox, cutOffset)
for grid in fecGrids:
	newGLine = createDatumLine(boundLines, grid)
	if newGLine and True:
		grid.SetCurveInView(DatumExtentType.ViewSpecific, activView, newGLine)
		outLst.append(newGLine)
OUT = outLst
another version here
> [@Change the Curve that determines the 2D extents of Grids in Each View](https://forum.dynamobim.com/t/change-the-curve-that-determines-the-2d-extents-of-grids-in-each-view/72886/13):
> Here an update code there will surely be cases where it will not work import clr import System clr.AddReference('ProtoGeometry') import Autodesk.DesignScript.Geometry as DSGeo from Autodesk.DesignScript.Geometry import \* #import Revit API clr.AddReference('RevitAPI') import Autodesk from Autodesk.Revit.DB import \* import Autodesk.Revit.DB as DB #import transactionManager and DocumentManager (RevitServices is specific to Dynamo) clr.AddReference('RevitServices') import RevitServices from Rev…
_[View the full topic](https://forum.dynamobim.com/t/grid-extents-alignment-based-on-crop-region/55538)._
