Hello @dhilipseshan
you need to get the “cut elevation” CutPlane of the view to set elevation of bounds curve (CropBox)
an example with the active view
def createDatumLine(boundLines, grid):
gridLine = None
curveG = grid.Curve
vectGrid = curveG.Direction
ptmid = curveG.Evaluate(0.5, True)
lstPtToLine = []
for lineBound in boundLines:
interResult = lineBound.Project(ptmid)
vectInterResult = Autodesk.Revit.DB.Line.CreateBound( ptmid , interResult.XYZPoint).Direction
if vectInterResult.IsAlmostEqualTo(vectGrid, 0.1) or vectInterResult.IsAlmostEqualTo(vectGrid.Negate(), 0.1):
lstPtToLine.append(interResult.XYZPoint)
if len(lstPtToLine) == 2:
gridLine = Autodesk.Revit.DB.Line.CreateBound(lstPtToLine[0], lstPtToLine[1])
return gridLine
def getBoundLines(bbx, Zvalue ):
lstPt = []
lstLine = []
lstPt.append(XYZ(bbx.Min.X, bbx.Min.Y, Zvalue))
lstPt.append(XYZ(bbx.Max.X, bbx.Min.Y, Zvalue))
lstPt.append(XYZ(bbx.Max.X, bbx.Max.Y, Zvalue))
lstPt.append(XYZ(bbx.Min.X, bbx.Max.Y, Zvalue))
for idx, pt in enumerate(lstPt):
if idx == 0:
lstLine.append(Line.CreateBound(lstPt[- 1], pt))
lstLine.append(Line.CreateBound(lstPt[idx - 1], pt))
return lstLine
activView = doc.ActiveView
cropBox = activView.CropBox
viewRange = activView.GetViewRange()
cutOffset = viewRange.GetOffset(PlanViewPlane.CutPlane)
fecGrids = FilteredElementCollector(doc, activView.Id).OfClass(DatumPlane).ToElements()
outLst = []
boundLines = getBoundLines(cropBox, cutOffset)
for grid in fecGrids:
newGLine = createDatumLine(boundLines, grid)
if newGLine:
grid.SetCurveInView(DatumExtentType.ViewSpecific, activView, newGLine)
outLst.append(newGLine)
OUT = outLst
