Give structural continuity to the pillars
hello friends, I am modeling this building with rotation of levels and I want to give structural continuity to the pillars, I could do in levels 1 and 2 by joining two points of a line, but in all levels I could not do it and opted for another variant, using the node Line.ByStartPointDirectionLength, but I can not give the rotation in the Z axis, I appreciate the help in advance and any suggestions, I share the images, greetings!
Why not build a polycurve from the points making up each of the stacked columns and extract the curves from that?
Thank you very much Jacob, your advice is very accurate, I had not noticed, I am going to make that connection and I will inform you.
Perfect!!
