How do I get the new IF node to work like the old one??
Use a code block:
@PauLtus,
but what is the common sence? which information do you want to get? that points are at the same place?
I have to admit that I don’t have a clever response.
I simply had the same problem where I used If
nodes which then didn’t work in later versions. I played around with list depths on the new If
for quite some time but I couldn’t get it to work, but replacing it with a code block did.
ow theres a vector reverse you cant see when a point intersects with something I dont want and moves to the other side
