Hi all,
I am trying to write a script which can search for intersections and when found, parameter in instance (host) needs to be filled with info from the linked file object.
The instances in host are unhosted (so not face based for example).
I set up a little project to work this out (see below).
- blue is the linked file;
- one instance in space (ID=83797)
- one instance in wall of linked file (ID=84288)
- the wall containing instance (ID=663387)
This is my script:
How do I get only my wall-ID (663387) and my instance-ID (84288)? Instead of both instances.
Hope I made my self clear about this issue.
