Dear Dynamo users,
I’ve got a question for you.
I’m trying to create this custom node in Python with the method GetAssociatedFamilyParameter(),
from the FamilyManager class.
When I’m running this in Dynamo it’s telling me that the method requires two arguments (one is given)
The RevitAPIdocs says (from the C# syntax):
public FamilyParameter GetAssociatedFamilyParameter(
Parameter elementParameter
My question for you is: where’s/what’s the second argument?
clr.AddReference(“RevitAPI”)
dataEnteringNode = IN
elems = UnwrapElement(IN[0])
outlist =
for i in elems:
try:
outlist.append(FamilyManager.GetAssociatedFamilyParameter(i.GetParameters(‘Visible’)))
except Exception as e:
outlist.append(e)
OUT = outlist
This is without running the code with the exception part:
File “”, line 13, in
TypeError: GetAssociatedFamilyParameter() takes exactly 2 arguments (1 given)
I have been getting similar issue’s between the number of arguments required with the Revit Api saying 2 Arguments for C# and then and error message and asking for 3 arguments in python in Dynamo for SetSketchPlaneAndCurve(), but not telling me anywhere why or what the miss argument is.
I am also yet to find away in Python in Dynamo or Visual Studio that when you open the bracket it gives you an idea what is required in the same way as Design Script does in dynamo code blocks.
Yes, I’m in the family environment.
The input is a list of Filled Regions, and for every i in the list i want to take a closer look at the “Visible” parameter and check which family parameter it’s associated with.
And yes, the Filled Regions are placed in the active document.
Try making it work for a single filled region and remove the for loop. Might shed some light. I have seen this happen because there is a similar API call which Revit is trying to use, but I cannot think of which it would be offhand.
I tried to send in only one element and removed the loop.
Did not work.
I’ve experienced this with several other methods as well, just as @Matt_Gaydon.
Any thoughts?
Yeah, so I tried to do that before and it tells me it expected FamilyManager. I know for some methods you need to construct a new, in this case a FamilyManager, for it to work. Like with a filter, the Create method. But I couldn’t find anything like that.
So, the GetAssociatedFamilyParameter expects (FamilyManager, elementParameter)(?)
Keen eye there @SeanP but something is telling me that isn’t the issue though.
Since Dynamo is finding the method and I’m in the family document (and now got a reference to it), Dynamo is basically telling me that “Hey, I know this method but you still need one more argument for this to work”.
Please, correct me if I’m wrong here but shouldn’t it be explicitly mentioned in the RevitAPIDocs even though it was a reference or not.
In some methods it says “doc Current Document” as an argument.
It was exactly as you told me @SeanP, I added the family manager as an argument in the GetAssociatedFamilyParameter. As for the LookupParameter() vs GetParameters() they both work. The difference is that GetParameters() returns a list of parameters, which I guess is helpful some times.
This is the piece of code is used to get it working:
