I have a little bit of a problem trying to write data to a text file. The issue is that I can’t figure out how to work with the data I get.
I thought I’d stringify the data. I was able to do that for just one line using the “String from Object”-block, but now I do have over 10k lines of points so that doesn’t help me. (UPDATE: Used “stringify” by mistake instead of “str”.
I’d essentially need the data written to be the ID, the name and the point so that I can investigate the data further with python, but I’m a little stuck at the first step.
Not too impressively I’m stuck here.
I tried to get the type of the incoming data to perhaps understand how to work with this but I got the output “ironpython.runtime.types.pythontype” which I unfortunately don’t understand, not even with the help of Google.
