Hi all
Is there a way to get text and type name in element parameters,and will get text and type name into excel ?
Thanks in advance.
Fanny
Hi all
Thanks in advance.
Fanny
Hi Fanny,
Use “Element.GetParameterValueByName” node and type in string as your parameter name elements list in element. Then you will get Parameter values. You can use later “WritetoExcel” node to write your values to excel. Good Luck!
Hi Kulkul
Problem solved,thank you kulkul for your great support so far!
Fanny
