I want get PipeInsulation reference to spot bottom elevation,but this PipeInsulation I use element.reference get wrong offset reference。
Hi
here is a workaround building a “custom Reference Stable Representation” to get the bottom line reference
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB.Plumbing import *
def createSpotBottom3(pipe):
global lstPara
lstspot = []
lstinsulationId = InsulationLiningBase.GetInsulationIds(doc,pipe.Id)
if lstinsulationId:
insulation = doc.GetElement(lstinsulationId[0])
refStable = Reference(insulation).ConvertToStableRepresentation(doc)
refToDim = Reference.ParseFromStableRepresentation(doc, refStable +":9:LINEAR")
curve = insulation.Location.Curve
refStable = Reference(pipe).ConvertToStableRepresentation(doc)
refToDim = Reference.ParseFromStableRepresentation(doc, refStable +":17:LINEAR")
curve = pipe.Location.Curve
for p in lstPara:
origin = curve.Evaluate(p, True)
bend = origin + XYZ(2,2,-2)
end = bend + XYZ(4,0,0)
spot = doc.Create.NewSpotElevation( doc.ActiveView, refToDim, origin, bend, end, origin, True)
lstspot.append(spot)
return lstspot
toList = lambda x : x if hasattr(x, '__iter__') else [x]
lstelems = toList(UnwrapElement(IN[0]))
lstPara = IN[1]
outSpot = []
for e in lstelems:
if isinstance(e, Pipe):
outSpot.append(createSpotBottom3(e))
OUT = outSpot
Note:
- trick to find the index Reference with Revit Lookup
- article about Reference Stable Representation
Thanks for your assistance in this problem so much, how kind you are to help me.
