Hi everyone
It is my goal to get the intersection area of an opening and the cutout wall.
I have the size of my object and want to see if it is placed properly “inside” the wall which would mean that the intersection-area is the same as the intersection object.
Currently, I only have the possibility to check this before doing the cutout. In this case, I take the Element.Geometry of both objects and take the Geometry.Intersect. This way I get the area of the cutout. This is performance consuming and does not work anymore when the opening is cut out from the wall, because the Wall has a whole now and does not interesect anymore.
Is there any way I can get the intersection area of an object after cutting the opening out of an object?
Thanks and kind regards,
Jannis
This is the shape i would like to get the area of:
